Author Topic: 90+ Brake Plates  (Read 3311 times)
Offline giz.neal
90+ Brake Plates
« on: 04 Jan 2018 at 10:04 »
Gentlemen,
2 queries:
The small grease nipples located in the brake plate for the 'cam operating' shaft specific to the Plus (as opposed to the ones in the end of the shaft for the Mk series, Plate No 27, Pt No SA.1496), what size are they?
It appears that the 'cam operating' shafts for the plus are of larger diameter to the Mk item, is this correct for the Plus?
Yours
Steve Neal
Offline kncken
Re: 90+ Brake Plates
« Reply #1 on: 04 Jan 2018 at 21:33 »
Happy New Year,Steve.I just looked at my dismantled Plus brake plates and the grease nipple on the rear item measures 0.185inch(3/16th inch) so maybe BSF OR 2BA?Regarding the 'cam-operating shafts',both of my Plus items,front and rear,measure 0.562inch (9/16 inch),and my Mark ones are both 0.496 inch (half inch).Hope you are keeping well these days? Best wishes,Ken Playfoot.
Offline giz.neal
« Reply #2 on: 08 Jan 2018 at 15:18 »
Ken,
All is well. Yes your measurements confirm my findings, thanks! Hope you are well
Steve
Offline Brian
« Reply #3 on: 15 Feb 2018 at 14:53 »
I'm pretty sure the small grease nipples are 3/16" BSW as opposed to BA.They are found on eBay under Bicycle parts;used I think around bottom bracket lugs of "racers".I spotted some this week.
Brian
« Reply #4 on: 15 Feb 2018 at 15:10 »
Yes Brian, on my 90+ it is 3/16 bsf.
Offline Brian
« Reply #5 on: 15 Feb 2018 at 15:32 »
Here's a UK source,at least,for 3/16" BSF Grease Nipples. Beware of other offerings of 3/16" Nipples, with what look like threads but are annular ridges for drive fitting.
 eBay ref number 142443423179  £7.95 inc UK post for Packet of 10 3/16" BSF Threaded Nipples
Supplier is
Drive Belt Solutions Ltd
Halifax,W.Yorks HX3 8JA
Brian
Offline giz.neal
« Reply #6 on: 26 Feb 2018 at 08:46 »
Thank you all, job done.
Steve N
