2025-01-07, 19:16:39
Forgotten your password?
2024-06-11, 21:02:05
LEFT OVER PARTS FROM DOUGLAS RESTORATIONS FOR SALE.
Started by LATDOUGNUT, 01 Apr 2025 at 16:54
LATDOUGNUT
HELLO ALL,
I HAVE A FEW PARTS FROM A 1926 EW 350 LEFT OVER AFTER RESTORATION AS PER PHOTOGRAPHS ATTACHED. ALSO A CIRCA 1922 4 HP DOUGLAS OIL FILLER EXTENSION -- BRASS, NEWLY NICKEL PLATED IN PERFECT CONDITION.
THE EW350 SPROCKET WAS MADE A-NEW, CASE HARDENED AND THE ID GROUND TO SIZE. ALSO THE CRANKSHAFT TIMING PINION IS A NEW-MADE PART. THE BRACKET HAS BEEN NICKEL PLATED. CLUTCH PART HAS A SECTION MISSING ON ONE SIDE. THE TOOL WITH 6 PINS WAS MADE TO UNSCREW THE VALVE GUIDES. THE PISTONS ARE CAST IRON , WITH PINS, BUT NO RINGS.
THE PARTS HAVE BEEN SENT TO A UK FRIEND IN NORTH LONDON, THEYDON BOIS NEAR EPPING. IF SOMETHING WOULD BE OF INTEREST I CAN DELIVER TO THE INTERNATIONAL STAFFORD MOTORCYCLE SHOW IN APRIL. OTHERWISE CAN POST AT COST...
I AM OPEN TO OFFERS.
JURIS -- THE BALTIC PIONEER
No Rest -- No Rust. No Trust -- No Bust!
