Phil,
Firstly, I think it's a little unjust to infer that the 'Club pistons' were at fault when, in fact, the timing must have been erratic and the major cause of the overheating and subsequent piston damage - which then, probably, resulted in excess stress on the bigends.
Anyway, regarding the need for a replacement conrod - in the past I have managed to resurrect conrods that have suffered in this way. The rods are made of a relatively soft steel, and providing there are no signs of any cracks, can probably be pulled back into shape. First of all, turn up a steel plug to fit the bigend eye of the good conrod, then tweak the damaged bigend until it fits neatly on the plug (you may need to 'blue up' the plug and scrape the eye to get it perfectly round). With the 2 halves of the rod a good fit on the plug, carefully dress up the joint faces. With this done, clamp the 2 halves onto the plug to determine what thickness the 2 new keep plates need to be. At this point, you can make new shells to suit - leave enough clearance on the bore (say 3-4 thou) so that oil can get in and lubricate the bearing. A tight bearing will eventually nip up, and on cooling, will curl tighter around the pin - making the problem even worse.
If pistons are proving to be a problem to find, Postwar Mk type pistons can be modified to fit - my TT 2¾ was fitted with them back in the '70's, and has now done thousands of miles without any problems.
Good luck with the repairs,
