Matt,
Most riders of later Marks and Dragonflies seem to get good results from NGK B7HS plugs. Since the introduction of unleaded fuel here in the UK, we have found that some readjustment of the carburation may be necessary. In my case, I have gone up 10 on the main jets, reduced the slide cutaway by about ½ (3½ instead of 4) and then compensated by fitting the needle clip in the top groove. If the plug that fail shows black/oily and then works OK after cleaning, I would try one grade softer, so that it runs a little hotter.
Good luck,
