Author Topic: Mechanical tips and help needed in Brisbane  (Read 6140 times)
Offline Dougie
    • Classic Bike Sales
« on: 15 Apr 2010 at 09:51 »
Hi wonder if any one can help me i am in Brisbane Austrlaia, need some help with the clutch on my 47 Douglas, any mechanical advice on site would be good,will pay for any help,think its a clutch problem maybe cable or clutch jammed?
Any help would be great.
The Spirit of Douglas
Re: Mechanical tips and help needed in Brisbane
« Reply #1 on: 16 Apr 2010 at 17:11 »
Come on Dougie, give us half a chance, give us some idea of the symptoms - after all, our area of expertise is supposed to be 'Douglas', not mind reading.
Offline Dougie
« Reply #2 on: 16 Apr 2010 at 21:51 »
Well the kick start is jammed, also the clutch is all free play, and does not improve with adjustement, was fine the other day, but not now!
Offline Keith
« Reply #3 on: 16 Apr 2010 at 22:40 »
Hi Dougie, this sounds more like a gearbox problem.
Can you select gears by rocking the bike backwards and forwards? or does it always feel like it's in neutral?
Keith
Offline Dougie
« Reply #4 on: 16 Apr 2010 at 22:49 »
Keith, No i can still select the gears and also get nutural.
« Reply #5 on: 17 Apr 2010 at 05:54 »
Dougie,
              The only time I had problems with a jamming kickstart, I found that the kickstart gear had split (out from the keyway) and was being wedged open by the key, causing it to jam against the mating gear.
              Regarding the clutch suddenly going out of adjustment - there are 2 ways of adjusting it. There is the normal fine adjustment on the cable, and there is a coarser adjustment by altering the position of the operating lever inside the bellhousing. This lever is held by a clamp bolt which may have come loose allowing the adjustment to drop away suddenly.
Offline Dougie
« Reply #6 on: 21 Apr 2010 at 09:42 »
Found the problem, the fly wheel had come loose causing the problem,only thing is i think the fly wheel is warped, can any one help with a fly wheel for this 47 t35 Douglas
« Last Edit: 27 Apr 2010 at 11:17 by Dave »
« Reply #7 on: 21 Apr 2010 at 11:32 »
Doug,
          If your engine has been running for any length of time with the flywheel loose, the taper on the crank and the bore of the flywheel will have fretted. Also the slot for the key may have a burr on it, causing the flywheel to run out of true.
     Try removing any burrs and then lap in the taper with fine grinding paste. with a bit of luck, the original flywheel will be recoverable. When refitting the flywheel, do the nut up as tight as possible. If the split pin hole does not line up - leave the split pin out - do not back off the nut to get the split pin in - this will only result in the flywheel coming loose again.
Offline Dougie
« Reply #8 on: 22 Apr 2010 at 06:47 »
Thanks for that Eddie,all is good now, have put it all back together everything is perfect, will put the engine back on the weekend
Thanks again for your support.
Dougie
Will be re doing the tank soon, give you a peek after its done.
Motor has now been fully done from top to toe.
« Last Edit: 27 Apr 2010 at 11:16 by Dave »
