For Douglas enthusiasts worldwide since 2004
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
General
General Douglas Discussion
Second fuel tap on tank of 2 3/4
« previous
next »
Print
Pages:
1
Author
Topic: Second fuel tap on tank of 2 3/4 (Read 5654 times)
gsx1100s
Senior Member
on:
31 May 2006 at 06:01 »
Does anyone know the function of the second tap located on the tank of the 2 3/4 Douglas. I understand the first is a fuel tap , the second though alludes me. It is located closer to the rider in line with the petrol tap.I have checked pictures of the same era and only found a single tap. Is my tank from a later model?
thanks in advance michael
Logged
"My first car was a motorcycle"
Ian
Master Member
Re: Second fuel tap on tank of 2 3/4
Reply #1 on:
31 May 2006 at 06:14 »
It is usually used as a fuel drain. I sometimes have a tap and sometimes just a blanking bolt
Logged
Chris
Master Member
Reply #2 on:
31 May 2006 at 07:42 »
All of my 2.3/4 hp models (four) and others I have ridden have two taps in the base of the petrol tank. One is obviously the fuel tap. Ian is correct, the other is the drain tap which terminates with a little cone shaped nipple. An interesting point is that the original Douglas drain taps have the tap operating in the opposite way from the fuel tap, i.e. the drain is shut off when the tap lever is in line with the tap body. The fuel tap is shut off when the lever is at a right angle to the fuel line. On some early models the drain tap is on the other side of the tank from the fuel tap and at the front. Chris
Logged
clee
Full Member
Reply #3 on:
05 Jul 2006 at 09:52 »
to go with what has been said, it is a drain for the OIL tank. regards col
Logged
colin lee
clee
Full Member
Reply #4 on:
05 Jul 2006 at 09:56 »
sorry, my mistake, it must be late. looking at 3 tanks, everyone is right, it's just plugged off. sorry about the first post. regards col
Logged
colin lee
Print
Pages:
1
« previous
next »
General
