Author Topic: T35. mk1 barrels.  (Read 2541 times)
Offline george sutton
T35. mk1 barrels.
« on: 30 May 2013 at 15:46 »
Hi all, i have found a pair of mk 1 cylinders, that are at std size, but are slightly pitted. They will take oversizeing. but what i would like to know please, HOW can one physically determine by (sizes ? weight? diamentions?) wether they are from generators or bikes ? i also have new +0.030"pistons .But need more info, before trying to pair them up. Denis.s
Re: T35. mk1 barrels.
« Reply #1 on: 30 May 2013 at 18:17 »
Denis,
          The bike barrels have the top fins relieved to clear the finning on the underside of the heads, whereas the generator barrels have full fins. Also, the generator barrels have a hole between the cam followers for securing the locating block that prevents the followers from rotating. The generator barrels can be used with the bike type full circle followers providing the block is removed. In all other respects, the barrels are virtually identical.
