When pulled off the left pinion I had to remember, there is a difference in the timing cases between standard T35īs and the Pluses!
There is less space in the Plus timing case. So it is not possible to free the pinion complete from the camshaft. It is necessary to split the crankcase and pull off the camshaft from crankshaft side.
So I did, and drive out also the camshaft with the damaged puller srew bore in the (warmed up) pinion. So the repair is easy now.
Phil, thanks for your advice.
There is a damage in the timing case on the oil pump side cam. The engine was run with a damaged tappet (broken off rotation plate!). This causes an ugly ex cam and a destroyed timing bushes + crankcase!!!
I have to think for an idea.
