Hi all,
The EW is finished at last and entered into the Banbury. I have been doing some shakedown runs to iron out any issues and have a perplexing problem which I am struggling to identify the cause. Under load, particularly in second but also in third the transmittion is juddering and sounds like it is missing a tooth. It is what I would expect the cush drive, outboard of the gearbox, to sound like if it was overrunning the face cam but there is no evidence of this on the cam. If you back off the power is stops and if you gently accelerate it is fine. Steep hills can be climbed gently in first but too much power causes it. I am aware of the layshaft and 2nd gear mod the club does but I am not sure of what the issue is that precipitated this mod and therefore what the symptoms are. Can anyone shed some light?
The gearbox was fully rebuilt with all new bearings and bushes and appeared in good nick with little if any wear to the gear teeth. It seems to select OK too.
The clutch, albeit a bit temperemental, is not slipping and the motor is sweet and surprisingly powerful for what it is.
Thanks for any advise.
Andy
