Spent some time yesterday checking the wiring , someone has been messing about with it.The horn button doesn`t do anything, until you turn the lights on then when pressed the lights dim and the horn doesn`t work. Also I think the dip switch is disconnected.If I try the horn on a battery it is OK, so a case of checking all the wiring.I can`t see any wire going into the Magneto at the moment so how does the cut out work.I havn`t got the bike started yet, I`m waiting for carb.parts.At least I have a spark on the plugs and good compression so that is one thing out of the way.
