Len,
If the choke plungers don't lock down, the spring clip is most likely worn or missing. In the carb top, there is the hole for the choke slide, across that hole there is a narrow slot. This slot should have a 'hairpin' spring in it that locates in the cut in the choke plunger. Having said that, the bike should start without the need of the choke slide (providing you 'tickle' the floats).
You say you stripped and cleaned the carbs - did you remove the choke blocks? With the choke blocks removed from the carb bodies, on the engine side of the block and just below the main choke, there is a shallow drilling (about 4mm dia) - that drilling has a small hole going up to the main choke, another larger drilling to one side, and a very small drilling in the centre - this is the slow running petrol feed and can easily get blocked (resulting in no tickover and difficult starting).
Regarding the magneto brush - these can be obtained from any of the magneto repair specialists.
