A hint and a note on safety.
If a Douglas - or any bicycle or motorcycle - has a spreader system to clamp the handlebars in the steering stem, the best approach is to loosen the bolt about 1/2" - it will rise up from the handlebars as it will still be well engaged with the thread of the spreader nut - then tap the head of the bolt downwards with a soft-faced hammer. This will cause the tapered spreader nut to disengage with the bottom of the handlebar stem, hopefully allowing the joint between the handlebar stem and the inside of the steering tube to loosen.
Re safety: If one of your spindles breaks at your nominated touring speed of 45 mph you will most likely have an horrific accident. Usually when a spindle or the steering tube breaks, the front wheel shoots forward and the lower front part of the frame hits the tarmac. If it digs in, the rider will... enough said. Pieces of shim wrapped around spindles is the sign of (a) massive wear and (b) a previous owner who was not an engineer. Please, please, please have someone with a strong engineering background have a look at the forks. While wear in the spindles themselves is bad, wear where the links move on the stepped part of the spindle, where it is smaller diameter, is almost always present and possibly more dangerous. If you spend time or money anywhere on the bike it should be on the forks and steering head. It's really important to understand how the fork is meant to work. In particular the links must be pulled up dead tight onto the shoulders of the spindles, and the spindles must be a snug fit in holes in the links. There should be no movement whatever, ever, between the links and the spindles. The top and bottom pairs (2 links + 2 spindles) should be rigid rectangles. This also means that it is imperative that the four holes (top and bottom of the steering tube, top and bottom of the fork girder) are not only bored round, but also they must be parallel to each other. If not, the fork won't move up and down without sticking. It's a tricky job - I have a local machine shop trained in the art, and the forks produced are a revelation. Be sure also to use only an appropriate steel for the spindles (with a good core strength, maybe 4140). "Silver steel" or "stainless steel" won't do.
Please ask here if you need any more info.
