Can anyone help with information on the correct dimensions for the T6 valve springs ?
That is; Spring rate, number of active coils, wire diameter, OD of coils and free length.
I did purchase some springs through the LDMCC spares but have found them by design needing over double the force required to open the valves compared to the ones originally fitted. Not good for the timing gear train and cams, or easy starting.
I would like to know if the originals were the correct size springs.
ChrisS
