Zac,
As this bike is something of an unknown quantity to you, it would pay to do a few basic checks.
Firstly, has it been set up to run on petrol or methanol? If it is setup for petrol, the main jets will be about .050" dia bore. For methanol they will be more like .080"(or larger!).
Secondly, do a rough check on the ignition timing - it should be around 38 degrees before TDC.
With these checks done, apply a few drops of engine oil to the valve stems and rocker gear. Then prime the engine with one pumpfull of oil using the hand pump in the tank. Turn on the fuel and tickle the carbs until they flood. You should now be ready to bump start it. With the motor turning, bring up the throttle gently - too much throttle will cause it to fire and kick back - even with the ignition somewhat retarded!
Obviously, bump starting can be somewhat worrying - especially with a machine you with which you are not familiar. If you are still having problems getting it started, why not bring it along to the Douglas Club rally - there will be members there who have enough experience to help you out. I, for one, will have my DT based sprinter, and a set of starting rollers (a lot easier than bump starting!).
Looking forward to meeting you,
