For Douglas enthusiasts worldwide since 2004
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Help
Search
Login
Register
Douglasmotorcycles.net
General
General Douglas Discussion
Rear Brake Blocks for a 1913 2+3/4 ?
« previous
next »
Print
Pages:
1
Author
Topic: Rear Brake Blocks for a 1913 2+3/4 ? (Read 3403 times)
phil_h
Full Member
on:
02 Feb 2011 at 19:49 »
Can anyone advise where I can get one from in England please ?
thanks
phil
Logged
oily bloke
Senior Member
Re: Rear Brake Blocks for a 1913 2+3/4 ?
Reply #1 on:
03 Feb 2011 at 06:00 »
Hi Phil,
I presume you have tried the VMCC brake block scheme?
Andy.
Logged
MRD
Full Member
Reply #2 on:
03 Feb 2011 at 14:36 »
Hi Phil
The VMCC do not have the brake block specifically for the earlier model 2 3/4hp but they do have a "Slab" which you will have to shape to fit.
The web page you require is:-
http://www.vmcc.net/vmccshop/scripts/brakes.asp?cat=14
There is a check out tab at the bottom of the page so I'm guessing that you don't have to be a member to buy.
I hope this helps.
Regards Martin
Last Edit: 03 Feb 2011 at 14:42 by MRD
Logged
phil_h
Full Member
Reply #3 on:
03 Feb 2011 at 17:07 »
Thanks, I had hoped not to have to do any 'whittling', but when I get the engine back together with its new pistons and valves I will definitely need it to stop a little bit better
Any recommendations on high-friction boot-sole materials anyone
Logged
Print
Pages:
1
« previous
next »
General
