As Doug said, these four speed gearboxes had variations in design of the cases. This looks to be one of the first type which often suffered from damage due to overtravel of the kickstart quadrant. On this type, the kickstart lever is best set to be just above horizontal when at rest so that when operated, the lever hangs vertical without the quadrant striking the inside of the top of the case. Later versions had the case modified to allow more clearance. A third version had the kickstart mechanism altered, with the ratchet mounted on the outer case - identified by a second boss directly below the kickstart shaft. This third type had a modified layshaft to go with the new rachet assy. Also, at some time the gear tooth form changed from 'stub tooth' to 'involute tooth'.
