Author Topic: Some photo's of Eric's DT  (Read 9089 times)
Offline Daren W Australia
« on: 15 Oct 2005 at 23:29 »
Hi Here are some photo's of Eric's DT in Sydney Australia
Regards Daren
Larger view here
Larger view here
Larger view here
Larger view here
Larger view here
« Last Edit: 16 Oct 2005 at 07:52 by Dave »
Offline Dave
Re: Some photo's of Eric's DT
« Reply #1 on: 16 Oct 2005 at 07:54 »
That's a beautiful machine Daren. Did you take the photos? And who's Eric?
« Reply #2 on: 16 Oct 2005 at 10:46 »
Hi
 Eric has owned this for a long time he has a few questions to ask those in the know. Does anyone have frame dimensions for this bike as it may have been shortened when racing pre-war you can also see a kink in the lower tube of the rear frame it may also have been shortened ? It also has an OB gear box doe's anybody have a spare DT box or a case to sell as you can see it not just a pile of bits but a total restoration.
 Eric has many Douglas including a S1 with extensive race mods including a very short wheel base.
 These photo's were taken a few weeks ago if any Douglas fellow's need other close up pic's of the DT or S1 just ask.
Regards Daren.
Ps I'm first in line for a push start.
Offline Dirt Track
« Reply #3 on: 17 Oct 2005 at 10:51 »
G'day All
I would love some close up photos of the S1 please Daren.
Say hello to Eric for me....has he been able to prize that S1 front brake out of the other Daren?
Howard.
Offline Dave
« Reply #4 on: 17 Oct 2005 at 10:55 »
Yes, I'd like to see some too Daren - some wide shots too please - similar to above.
  • Global Moderator
« Reply #5 on: 18 Oct 2005 at 02:36 »
Gearbox case for DT/SW models newly listed on Ebay, posted here:
http://www.douglasmotorcycles.net/index.php/topic,935.0.html
Offline Earlyriders
« Reply #6 on: 10 Nov 2005 at 06:28 »
Hi Daren,
I too was bidding on the gearbox case but it got a bit expensive so am going to cast some up. I have a '26 TT and a '29 DT and both cases are faulty. Given the thinness of the cases and the material that Douglas cast them up from welding is extremely hard. Anyway you requested some dimensions on the DT frame. Are you still after them as I can measure mine up if required. Regards, Ian.
Offline Dave
« Reply #7 on: 10 Nov 2005 at 08:59 »
This is just a "bump" post in case anyone missed Earlyrider's message above. We were fiddling around with this thread and may have accidently turned off the  "New Post" icons.
