I am looking for some parts for my 1954 Douglas Dragonfly. I wonder if anyone could help me?
I am in need of the following parts:
• Lock washer - 34827
• Lock washer - 26394
• Lock washer - 25769
• Lock washer - 29463
• Shim between housing and gear case - 34466
• Front sprocket 17 tooth - 37659
• Joint gearchange cover - 26036
• Washer for cover - 34213
• Joint washer for cover - 25968
• Gasket for gland - 34368
• A matched pair of a final drive pinion gear and a crown wheel type gear to go with it (Beval pinion 26 teeth output gear - 29596, Beval pinion 14 teeth output gear - 25976)
I would be very grateful if you could point me in the right direction of where I might find any of these parts.
-Andrew
