Author Topic: 1950 MK5 parts needed  (Read 683 times)
Offline martin1
« on: 29 Jan 2018 at 08:49 »
Hello Douglas family,
I am currently restoring my Douglas MK5 from 1950. I have bought many parts from the club´s stock but there
are some things that they don't have. It is actually 3 things I would need:
1. Clutch Friction disc ( you can see that the inside is heavily worn, strange enough - the counterpart is still in good shape )
2. Left cylinder head ( mine has a crack between the exhaust valve and the plug thread )
3. Timing gear ( See photo, this one is worn out - the counter gears are OK )
I would be very thankful for any help in this respect.
Regards from snowy Austria
Martin
Offline douglas1947
Re: 1950 MK5 parts needed
« Reply #1 on: 01 Feb 2018 at 05:48 »
Hi Martin,
your center of the friction disc is indeed very worn; I have no idea to help.
The crank in the MK5 head is not unusal. On my MK4 engine both heads are welded (in former times).
I think there a good special welding shop can repair it!
The cam idler weel looks not too bad?!
Won´t you try to overhaul it?
Offline martin1
Re: 1950 MK5 parts needed !!!!
« Reply #2 on: 26 Mar 2018 at 15:43 »
Hello Douglas Family !
I have sorted out all problems and found parts for my projects except the left cylinder head.
Welding did not work out and that's why I am back here at the forum and would once again
ask for help.
I am looking for an MK4 MK5 left cylinder head ( without cracks  :) )
Many thanks for checking your "sheds"
Martin
