Author Topic: Tank fittings Wanted  (Read 866 times)
Offline GlennMckenzie
« on: 28 Jan 2018 at 01:10 »
Hi Forum members,
Wondering if anyone would have a rough 1920's or Veteran tank laying around in unusable condition.
I need a doner Tank for the fittings only.
I recently tracked down a very rough Veteran Tank that looks to be 1912 ish due to the small diameter oil cap hole and the lack of a gear shifter hole. I'm trying to salvage it and convert it slightly to suit my recently purchased 1917 Douglas project.
The bottom was completely rusted out and both sides had large rust holes but Iv managed to solder some patches on the inside to hold it all together.
Thanks for looking, Glenn
Offline RockDr.
Re: Tank fittings Wanted
« Reply #1 on: 28 Jan 2018 at 09:31 »
Hi Glen,
Have you tried Ivan Wilson in Cairns. He makes new tanks and also new fittings as well as fixes old tanks. If you have no luck on the forum just pm me and i will give you his details
Chris
« Reply #2 on: 28 Jan 2018 at 11:05 »
Thanks Chris,
Can you PM me his contact info please.
Glenn
« Reply #3 on: 28 Jan 2018 at 21:00 »
Hi Glenn
If that is the original paint on the tank it is later than 1912, there would be 3 panels on the side if original. The lack of a gear change hole is a bit puzzling though for sure
Offline RockDr.
« Reply #4 on: 31 Jan 2018 at 01:09 »
Hi Glen,
Pm sent.
Offline Eric S
« Reply #5 on: 31 Jan 2018 at 10:53 »
Just a dumb question. Why do you exchange commercial adresses through pm. Is this is not allowed on the forum?
I guess it might be helkpfull to others looking at this post in a few months.
