Author Topic: OC Compatible Gearbox and clutch requested  (Read 548 times)
Offline OCTypeCanada
« on: 23 Jan 2018 at 16:29 »
I am looking for a gearbox that is original to an OC Type (1926/27) or a compatible Douglas replacement.  The OC (Doug’s input) used a "UG" prefix box, as did TT, and SW types.  I would prefer conventional road ratios (YG prefix (DT type) has close ratios) but I would consider what you have.  TG and VG prefix case numbers should work (originally wide ratio) and SG (close ratio).
I will also require a clutch if anyone can provide that with or separately from a gearbox.
Thanks, Gord
Re: OC Compatible Gearbox and clutch requested
« Reply #1 on: 23 Jan 2018 at 19:56 »
If you use the standard OC gearbox you will I think need the flywheel clutch
