Author Topic: Aligniment crankshaft S6  (Read 461 times)
Offline Kalle
« on: 27 Dec 2017 at 14:48 »
Hi Michael
Wishing you a Happy New Year, it will be brighter now for every day that goes.
Thank you for your tip. I wonder if you made an alignment on this S6 axis that has three-pin pins see the photo as it is not possible to knock around the crankshaft pin. My thought is to put the crankshaft in a press and push it in the corresponding direction. Another method I was thinking of is putting it in a vice and using a tube to break back the shoulders
BR Kalle
Offline douglas1947
Re: Aligniment crankshaft S6
« Reply #1 on: 27 Dec 2017 at 19:39 »
Hi Kalle,
sorry, I have never seen this kind of crankshaft (S6) and no expirience with it!
I have only repaired T35 crankshafts and some single crankshafts, all have no stops on the crank bearing pin.
May be you will find out you have a better alignment, when you control the crankshaft on a prism (so you have no difficults with mistakes you can get, when controling in your lathe).
This construction of the S6 crankshaft seems to be for constant fixing with no possibility for changing the position!?
May be someone other can let us know about it!
Offline Bert
« Reply #2 on: 27 Dec 2017 at 21:16 »
Hi Kalle,
It looks like you have no radical adjustment with the pinned crankshaft. You should still have lineal adjustment which can be done by using wedges between the cheeks (vertical parts) to open them up or a vice to squeeze them together however this would apply even pressure on both cheeks. To move one cheek only you could try resting one cheek on a solid surface and striking the other side with a mallet. Go easy, a thou or two each time.
  • Global Moderator
« Reply #3 on: 27 Dec 2017 at 22:13 »
Kalle,
The factory practice with the S6 crankshaft (and probably others from the EW to the Aero) was to get it very closely aligned, pin the joint, and then do the final grinding of the main journals. For it not to line up, the throws have to be sprung or it is a crankshaft built up from components of more than one crankshaft.
First, study if springing the crank as Bert suggested will bring it closer to true. If it needs a radial twist and the pins are preventing you from doing that, the accepted practice is to remove the pins, do the alignment, and then re-bore the pin holes for a slightly larger dowel (like 5mm).
Do not be tempted to leave the pins out, you cannot tighten it up enough to stop it from slipping.
Offline Kalle
« Reply #4 on: 29 Dec 2017 at 17:46 »
Hi Douglas friends
Feel very good that you are on the forum to discuss the alignment of crankshaft.
I'm trying to insert the screw and nut and try to change the shafts position.
If that fails, I would probably ask a workshop to align and lock the position with 5mm pins that Doug writes about.
Thank you for your help and Happy New Year to you
Br Kalle
Offline douglas1947
« Reply #5 on: 31 Dec 2017 at 18:39 »
Hi Kalle,
I think you will let us know the result of trueing the crankshaft in "next year".
I hope you can mange it without touching the pins.
All the best to all for 2018!
Offline Kalle
« Reply #6 on: 04 Jan 2018 at 10:43 »
Hi Michael
Have a good start for the new year
I will notify you when I get the crankshaft in the best way, maybe I will leave it to a workshop so I will be satisfied
Br Kalle
