Author Topic: Douglas flywheel  (Read 998 times)
Offline Brett.Wade
Douglas flywheel
« on: 16 Dec 2017 at 06:50 »
Hi
Does anyone know if or what model Douglas these flywheels are from.
They came in a box full of mostly 2 3/4 parts. Obviously they don't suit a 2 3/4.
Brett
  • Global Moderator
Re: Douglas flywheel
« Reply #1 on: 16 Dec 2017 at 17:18 »
Brett,
Don't know what they are from, but definitely not any model Douglas ever made.
P.S. Any relation to Wade camshaft family?
Offline Brett.Wade
« Reply #2 on: 17 Dec 2017 at 05:06 »
Thanks Doug
I didn't think it was off a Douglas bike.
No relation to Wade Camshafts that I'm aware of.
cheers
Brett
Offline friday
« Reply #3 on: 17 Dec 2017 at 18:09 »
are there numbers on it ? looks v twin maybe
what is the distance from pin to crank centres ?
HD  1.90625
Indian  1.53125 or 1.75
bsa ?
Offline Brett.Wade
« Reply #4 on: 18 Dec 2017 at 00:08 »
Numbers cast into both flywheels are "150 20 D", one side has an "A" the other has a "B"
The distance from crank centres to the conrod pin is 2.0"
It doesn't appear to be for a twin, more likely a big single, possibly BSA WDM20????
Offline friday
« Reply #5 on: 18 Dec 2017 at 01:38 »
yea HD has 150 numbers . those FW you have = 4" stroke or 3-31/32" stroke
HD 750 = 3-13/16" stroke
http://victorylibrary.com/tech/casting-number-c.htm
there wouldnt be a timing side indian crank case amoung those parts ?   (1920 - 27)
Offline Brett.Wade
« Reply #6 on: 19 Dec 2017 at 09:11 »
Thanks for the heads up..
I will look further into the flywheel numbers.
Sorry, no Indian parts in this box of bits.
cheers
Brett
