Author Topic: Oil drip valve  (Read 266 times)
Oil drip valve
« on: 10 Dec 2017 at 04:27 »
I would like to source a replacement tapered valve for the oil drip feed on my E28. Are the reproduced anywhere or is it  a case of make it ?
  • Global Moderator
Re: Oil drip valve
« Reply #1 on: 11 Dec 2017 at 17:02 »
Ian,
Don't know about a source for reproductions, but the same needle valve is used in the Enots drip sights used on the 1929 600EW (corbel mounted), the SW5, F/G31, and Aero models with slight variations on the hold-down method. Since it was bought in, presumably other makes used the same drip sight; it is not proprietary Douglas.
The attached picture is of the needle valve from my F28 (right) alongside the needle valve for my 600 Aero (left) with the Aero drip sight above. I did try the one in the other and it interchanged.
« Last Edit: 11 Dec 2017 at 19:37 by Doug »
Re: Oil drip valve
« Reply #2 on: 11 Dec 2017 at 18:49 »
Thanks Doug
