Author Topic: WTB 1925 Douglas CW gearbox  (Read 543 times)
Offline cruise98
« on: 11 Oct 2017 at 07:16 »
Hi Im chasing a Douglas 25 CW chain driven gearbox
I have got a early one i might consider trading or selling
Someone was saying this early one is rare i think he said it was a 2 speed 1915 ill have to research it more
I
Offline veikko1
Re: WTB 1925 Douglas CW gearbox
« Reply #1 on: 11 Oct 2017 at 09:07 »
Would you send picture other side from your box?
Regards veikko1
Offline cruise98
« Reply #2 on: 11 Oct 2017 at 09:33 »
Here you go
Offline veikko1
« Reply #3 on: 11 Oct 2017 at 20:30 »
Thanks your pictures. I have looking gearbox to my 1914 model, but yours look little later.
Regards veikko1
Offline cruise98
« Reply #4 on: 13 Oct 2017 at 05:17 »
Some numbers off it
« Reply #5 on: 13 Oct 2017 at 07:47 »
Strange???
    The Douglas patent 21259 of September 1913 (Improvements in the method of attaching speed change boxes to engines) shows a gearbox of the 4HP type clamped on a dovetail slide to the back of the engine. This gearbox carries that patent number, but is clearly of the 2¾HP type that bolts up under the frame. The only difference appears to be the extra lugs fore and aft to carry the clutch/kickstart mechanism (similar to the 1912 models fitted with a clutch). Another oddity is that it has the remains of what looks like a 4HP type clutch on the primary side rather than the normal cone clutch in the belt pulley.
Offline GlennMckenzie
« Reply #6 on: 14 Oct 2017 at 08:46 »
I would be very interested in the Clutch parts if you are able to remove them.
Sent you a private message with my number.
Offline cruise98
« Reply #7 on: 19 Oct 2017 at 06:56 »
More pics glen
Offline cruise98
« Reply #8 on: 19 Oct 2017 at 06:57 »
Another
Offline cruise98
« Reply #9 on: 19 Oct 2017 at 06:59 »
Another
