Author Topic: Timming Gears MK V.  (Read 928 times)
Offline phil1
Timming Gears MK V.
« on: 03 Oct 2017 at 14:01 »
Hi all,  Wanted camshaft timing gear R/H the one with dot, as I have two L/H ones perhaps someone would like my spare here's hoping there's no more surprises in this Douglas engine. Many Thanks. Phil 1.
Offline Neville Heath
Re: Timming Gears MK V.
« Reply #1 on: 08 Oct 2017 at 18:30 »
You can use the timing gears you already have. See my Spannerama book.
Neville Heath
Offline phil1
« Reply #2 on: 13 Oct 2017 at 07:17 »
Hi Neville,  I have your book to hand and may have misread, but my two camshaft gears are identical !, with a number one stamped  for the timing mark, I also notice there are no extractor holes, I feel these gears may not be original to my engine a mark v. PS my crank is at Alpha bearings for big end replacement so this gives me time to attend to other parts.
                                                   Regards Phil 1.
« Reply #3 on: 15 Oct 2017 at 17:15 »
Phil
When I said you could use what you had I meant you could use my book to work out a timing mark on a non-standard gear. L and R are NOT interchangeable as R keyways point to a space and L ones to a tooth. Now for the good news. I have found up a good R one you can have. Just send me the postage.
Neville
Offline phil1
« Reply #4 on: 24 Oct 2017 at 07:53 »
 Hi Neville, I have been away for a while so I apologise for my late reply. It is very good news that you have found a R camshaft Gear for me, just to clarify the two Gears I have are identical and have the keyway centrally aligned to a tooth and the timing mark on number 15 tooth. I was assured this was a runner when I purchased it!! I will forward a cheque to cover your postage today. Many thanks Phil. PS I have a box of miscellaneous bits if you need anything in particular.
