Author Topic: mark v frame  (Read 328 times)
Offline phil1
mark v frame
« on: 08 May 2017 at 20:07 »
Hi does any body know if the bottom frame rear link spigot can be replaced due to corrosion and much wear. Thanks, Phil1.
Offline phil1
Re: mark v frame
« Reply #1 on: 14 May 2017 at 09:33 »
Hi all, re my mark v rear frame bottom link pivot,  I have since done some work and have extracted said pivot from the frame tube, 1/2"studding sleeve tubes and some heat and out it came, a suitable replacement pivot can now be machined from your friendly machine shop. Regards Phil1.
