Author Topic: Douglas DT5, DT6 frame dimensions  (Read 1206 times)
Offline douglas-bg
« on: 23 Jan 2017 at 11:27 »
Hello to all,
may I ask if someone can help me with the three dimensions of DT frame?
Thank you in advanced
Best regards
Valentin
  • Global Moderator
Re: Douglas DT5, DT6 frame dimensions
« Reply #1 on: 23 Jan 2017 at 16:40 »
Offline douglas-bg
« Reply #2 on: 23 Jan 2017 at 17:49 »
Thank you very much Doug. Very fast and very detailed. Thanks again
Best regards
Valentin
Offline friday
« Reply #3 on: 25 Jan 2017 at 08:18 »
just curious , would you know what the steering angle is ?
It seems to be a lot of veteran bikes start at 20 degrees and evolved to 25 degrees as example then to modern era of 30 degrees .
speed way bikes like Jawa have 18 degree rake , sport / road bikes are 25 degree approx
The DT5 and DT6 look like they have more rake than std models , maybe just my eyes ?
« Last Edit: 25 Jan 2017 at 19:52 by friday »
« Reply #4 on: 25 Jan 2017 at 08:43 »
25 degrees.
Offline friday
« Reply #5 on: 25 Jan 2017 at 19:57 »
 :)  someones had their frame in a jig , means nice n straight
I was gonna say same as a velocette but just checked 27 degree for mss
