Author Topic: Sealing for Gearbox  (Read 1486 times)
Offline ManfrerdSt
Sealing for Gearbox
« on: 18 Dec 2016 at 14:54 »
hi Guys
Is there a good seal for Gearbox output T6?
What kind of lubricant do you use for the Gearbox?
     Manfred
Offline Dewey
Re: Sealing for Gearbox
« Reply #1 on: 20 Dec 2016 at 00:30 »
I believe most use groil or just fill with grease and let the gears carve their way thru it. That also helps to reduce any leakage.
Dewey
Offline Kalle
« Reply #2 on: 20 Dec 2016 at 13:20 »
Hi Manfred
You should use a grease type NLGI 00 or NLGI 000
This grease is used in centralized lubrication systems for trucks, buses and diggers
Uses self NLGI 00 My S6.
 Kalle
Offline ManfrerdSt
« Reply #3 on: 20 Dec 2016 at 15:46 »
Okay, this is a good tip! To grease from centralized lubrication systems, I have good access.
Can you still say what a seal behind the small sprocket comes into the gearbox?
     Manfred
Offline Kalle
« Reply #4 on: 20 Dec 2016 at 16:44 »
I have a leather ring with good fit to the axle then it is a cone in the outer path that allows the inner diameter is pressed against the shaft and is sealed.
Kalle
Offline ManfrerdSt
« Reply #5 on: 20 Dec 2016 at 18:00 »
Maybe someone knows the original parts?
Regards Manfred
Offline Kalle
« Reply #6 on: 20 Dec 2016 at 19:15 »
Hello again, you can see the leather seal and flanged washer in the top left corner of the photo, which  is inside the sprocket
Kalle
Offline ManfrerdSt
« Reply #7 on: 20 Dec 2016 at 20:14 »
Yes, now I understand!
Kalle, thank you for the effort!
     Manfred
Offline Kalle
« Reply #8 on: 21 Dec 2016 at 07:46 »
Hi Manfred
There will also be a short spring ring to push the flanged washer against the leather seal when the sprocket is there.
In my opinion this is the 3 parts art no 9809-1, 9810-1, 9811
Kalle
