Author Topic: Engine number YE16314  (Read 1610 times)
Offline jpc1974
« on: 07 Nov 2016 at 15:40 »
 hello
Can you tell me the model and the year with the following engine number YE16314
CYLINDERS ARE THEY BLIND
IS transmission CHAIN
I AM EXCUSE MY anlais TRANSLATED BY GOOGLE
Offline jpc1974
Re: Engine number YE16314
« Reply #1 on: 07 Nov 2016 at 15:53 »
Here the number of the picture
is it normal that the valve is offset relative to the pusher
the cylinder head is detachable
I wonder if the cylinders mounted on the engine are the right models
« Last Edit: 07 Nov 2016 at 17:57 by Dave »
  • Global Moderator
« Reply #2 on: 07 Nov 2016 at 16:23 »
The engine is a 350cc EW model, 1926-27. These initialy were blind cylinder but later were offered with detachable heads (as a Deluxe EW). The later detachable heads and cylinders will interchange with the blind cylinders.
The valves and tappets are offset. A large head on the tappet adjuster screw made up the difference of the offset.
Offline Boxer
« Reply #3 on: 11 Nov 2016 at 06:53 »
The idea behind offsetting the valves is that they so should rotate !
Rudolf
