Author Topic: EW Magneto Timing Gear Bearing  (Read 760 times)
Offline B.Shepherd
« on: 19 Oct 2016 at 17:58 »
Hi
I recently bought a 1926 EW which had a bearing case missing on the magneto timing gear, I have had a new casing made locally and was wondering which way the roller bearings sit in the casing? ie do they run on the outside of the casing or on the face of the timing gear, I have attached a photo showing the bearing running on the gear face.
  • Global Moderator
Re: EW Magneto Timing Gear Bearing
« Reply #1 on: 19 Oct 2016 at 20:10 »
