Author Topic: S6 ignition  (Read 856 times)
S6 ignition
« on: 15 Oct 2016 at 04:01 »
Hi folks
I've forgotten which direction the points face when timing on the front cylinder - could someone remind me please?
Cheers, Graeme
Re: S6 ignition
« Reply #1 on: 15 Oct 2016 at 06:42 »
Graeme,
              On BTH mags, the points usually face the cylinder that is firing - that is, when looking at the points, they are at 9 o'clock when the front cylinder fires. Unless you have disturbed the timing gears, it shouldn't be possible to get it firing on the wrong cylinder as the mag has a dog drive, so will only mesh in the correct position.
Re: S6 ignition
« Reply #2 on: 15 Oct 2016 at 23:23 »
Thanks Eddie
