Author Topic: CW Front Brake Linkage  (Read 1228 times)
Offline william Jonker
« on: 15 Sep 2016 at 18:05 »
 Can anyone help with parts or complete pivot assembly that operates the front pulley block brake. A drawing or sketch that I might use to fabricate it ?
Offline 9triton
Re: CW Front Brake Linkage
« Reply #1 on: 16 Sep 2016 at 01:07 »
which parts exactly? :
 pivot levers
pivot bolts?
side plates for brake block?
see my post here :
http://www.douglasmotorcycles.net/index.php?topic=5677.msg20587;topicseen#msg20587
 was helped by a UK member on here who could supply the raw parts that he did as a special run.
see if he chimes in
 we determined that the front brake side platesfor friction block  were different  to the backbrake  side plates - pivot holes were spaced diffenrtly - cant remember if was closer (or wider)
« Last Edit: 16 Sep 2016 at 05:38 by 9triton »
Offline 9triton
« Reply #2 on: 16 Sep 2016 at 05:25 »
ok here is a sketch done by forum member   for the pivots and adjustor bolts - very detailed :
the front lever arms are different to the back brakes lever arms  :
 from a web photo (again not mine)
 front brake on top half of photo
 rear brake on lower  half of photo
front lever arm:
on a abike - not mine :
« Last Edit: 16 Sep 2016 at 05:42 by 9triton »
Offline 9triton
« Reply #3 on: 16 Sep 2016 at 05:30 »
and for Info  a set that went on ebay Australia a year or so ago - no -I missed out on getting them:
