Author Topic: fork spring nut needed  (Read 1458 times)
Offline Daren W Australia
« on: 11 May 2016 at 07:12 »
Hi need a front fork nut with the 3/8" 25tpi thread of the front spring mount same as photo regards Daren
Re: fork spring nut needed
« Reply #1 on: 12 May 2016 at 07:59 »
Hi Daren
Assuming that the nut you are looking for is for the twin spring forks of 2.3/4 or 4 hp or even some later models then the thread size is 3/8" x 28 tpi not 25 tpi. In my restorations I have always re-manufactured these as invariably they are rusty and worn where they act as a pivot for the spring eyes. As a result I currently have plenty of these nuts in my scrap box. If you get no response to your request in Australia let me know and I will post you a couple. Chris.
« Reply #2 on: 12 May 2016 at 23:27 »
Thanks Chris yes it is 28 tpi I have ordered a tap on ebay will make some new ones Regards Daren
