Author Topic: frame numbers.  (Read 1373 times)
Offline drvrv6
frame numbers.
« on: 12 Apr 2016 at 20:20 »
hi .i need help looking up a frame and engine number.is there a set of frame number lists on here i can look up  .also need a manifold  from the carb to the cylnders .two spark plus maybe a carb as well.74 yr old computer trainee.
Offline Bert
Re: frame numbers.
« Reply #1 on: 12 Apr 2016 at 22:45 »
If you look at the posts directly above yours, you will find a link to the frame, engine and gearbox numbers.  If you are looking for parts you will need to identify the model you have.
Offline drvrv6
Re: frame numbers.
« Reply #2 on: 13 Apr 2016 at 20:38 »
looked it up it starts with 614 so looks to be 1923 .if thats correct hopefully you can point me in the right direction to get the parts.thanks bert
Offline Bert
Re: frame numbers.
« Reply #3 on: 13 Apr 2016 at 23:28 »
My only suggestion is to advertise in New Conrod, check eBay regularly (worldwide - eBay Oz has had a load of early parts recently), or keep asking on this forum mentioning the exact year and model.
