Author Topic: EW on magneto lever and other bits  (Read 1548 times)
Offline Daren W Australia
« on: 02 Mar 2016 at 23:50 »
Hi EW on magneto lever to swap for the right hand air lever or just the base
also I would like the seat spring clamp see photo mine is damaged
and someone enquired about gear change plates for EW i have a spare
I need 5 engine clamps to suit 600 27/9
Regards Daren
Offline Alan Cun
Re: EW on magneto lever and other bits
« Reply #1 on: 04 Mar 2016 at 08:41 »
Hello Daren, If you cant obtain the opposite base for your lever just have your casting man fill the cable section with wax and cast a new one. Then just bring your cable entry from the opposite. The rest of your lever is the same left or right. Ah yes may have to redo the bar radius under.
regards Alan
« Reply #2 on: 04 Mar 2016 at 09:41 »
Thanks Alan just of to the casting shop monday will have a chat with him Daren
