Author Topic: 90+ rear wheel  (Read 2251 times)
Offline roger h
90+ rear wheel
« on: 08 Nov 2015 at 20:00 »
Wanted - 90+ rear brake drum and backplate.
I have a spare 90+ front brake backplate and shoes which I can exchange or will sell if I can find the rear wheel parts?
I also have for disposal what I think is a competition model rear wheel complete with drum and sprocket.
Thanks,
Roger
Offline TonyC
Re: 90+ rear wheel
« Reply #1 on: 11 Nov 2015 at 22:23 »
Hi Roger,
I have borrowed a back plate for a 90+.
Can you confirm if it is correct and if so I will produce a pattern
Regards Tony
Re: 90+ rear wheel
« Reply #2 on: 16 Nov 2015 at 15:52 »
Hi Tony,
            As Roger hasn't replied, I can confirm that this is a 'Plus' brakeplate (hole for grease nipple is in the casting rather than the end of the cam).
Offline roger h
Re: 90+ rear wheel
« Reply #3 on: 25 Nov 2015 at 20:36 »
Looks right to me - boss for brake lever is larger than a Mark, and has the flat on the rear face to take the grease nipple. Also only one tapped hole for the chain guard, as opposed to two on a Mark.
Best wishes,
Roger
Re: 90+ rear wheel
« Reply #4 on: 25 Nov 2015 at 22:35 »
Two holes for the chainguard on Mk1 & 3. Single hole on Mk4 & 5. These holes are plain (no thread) - the flanged stud just has a nut on the inside.
Offline Dougiethenoo
Re: 90+ rear wheel
« Reply #5 on: 25 Jan 2016 at 01:45 »
Thanks,
Roger
Roger, do you still have the wheel and spare front brake?
Offline roger h
Re: 90+ rear wheel
« Reply #6 on: 30 Jan 2016 at 20:59 »
yes, I still have the front brake and the spare
wheel. We now think its a Dragonfly wheel..
Roger
