Author Topic: 1924 TS front cylinder  (Read 1717 times)
Offline carl denton
« on: 13 Apr 2015 at 12:27 »
hi all
just another parts I am looking for to get one more of my bikes on the road again is the front cylinder and any cast pistons .
got two motors I am working on and they both need front cylinders .
carl denton .
Offline shuswapkev
Re: 1924 TS front cylinder
« Reply #1 on: 16 Apr 2015 at 11:19 »
carl
  I have one extra cylinder...a front one ..and piston..  not sure what model...I will get a picture tomorrow,.. i have a few extra pistons...cast iron..has very steeply canted valves and only 2 bolts to hold cylinder on...not an ew cylinder
i bored my cylinders and fitted sleeves as one  had big rust pits..and the other was wine bottle shape   exact size at the spigot but near .040 bigger up near the top
cylinder is  a 350..  the piston has 4 rings...2 sets of 2...maybe they are called ringgs?
i,m looking for   26 ew , ex valve lifters..  the splined shaft for the brakes...kickstarter...a tank shift gate ...or even a paper rub pattern....magneto parts...front casting...points and points plate..... magneto gear....  pattern for gearshift  source to purchase fenders...tank oil pump...or any fragments of the above stuff
does anybody have a design to build a fender roller???
Offline carl denton
« Reply #2 on: 19 Apr 2015 at 06:12 »
hi
that would be good if you could send some photos .
