Author Topic: Douglas Engine No.77033 for Sale  (Read 3546 times)
Offline DavidS
« on: 01 Jun 2014 at 06:59 »
I have a Douglas overhead valve engine for sale. Engine number is 77033. The engine is complete with magneto but the timing cover is missing. I have had the engine for over 30 years and it is time for someone to use it! I am open to all offers. Location is Melbourne, but I able to help with shipping if required. Photos attached.
  • Global Moderator
Re: Douglas Engine No.77033 for Sale
« Reply #1 on: 01 Jun 2014 at 19:47 »
Hello David,
It is a 2-3/4hp side valve model engine. Serial number places circa 1925.
Offline joeis6
« Reply #2 on: 02 Jun 2014 at 06:55 »
can anybody tell me do the  manifolds on these motors have a fixed end and an adjustable end as this one in the photograph appears to have ?
neale
« Reply #3 on: 02 Jun 2014 at 07:40 »
joeis6
Yes! The flange is fixed at the rear end and sealed with a copper/asbestos washer. (now using an asbestos substitute) The forward end has a sliding tophat ring. This is best sealed with gasket cement coated string to ensure an air tight joint and allows for alloy crankcase expansion moving the cylinders apart with heat. Chris.
Offline joeis6
« Reply #4 on: 02 Jun 2014 at 23:09 »
Thankyou Chris. This is where the forum works so well , my restoration will be all the better all for the asking of one important question
neale
Offline duggy
« Reply #5 on: 22 Jun 2014 at 06:21 »
Is the manifold pictured on the floor for sale i;m looking for a side draft manifold thanks Colin
Offline hernny
« Reply #6 on: 22 Nov 2014 at 21:19 »
hello DAVIDS am interested for your engine gearbox you have it? few ask for the engine? I hope your answer Best regards HERNAN
Offline hernny
« Reply #7 on: 22 Nov 2014 at 21:24 »
