Author Topic: New DT tappet adjusters  (Read 2346 times)
  • Global Moderator
« on: 13 Oct 2013 at 22:33 »
For sale, new Dirt Track tappet adjuster screw (part #4360-1), and jam nut (part #h76).
Also fits: OC, 1925-28 TT, G/H28, F/G31-32, and 1934-35 OW/0W1.
Larger view
Larger view
The adjuster screw and jam nut are CNC machined from shock resistant S7 tool steel, vacuum heat treated and then air tempered to HRc57.
Fully interchangeable with the original, including the special 7/23-33 Douglas threads.
Cost is $18US per adjuster screw, jam nut included. Packing, postage, and insurance at cost.
D. Kephart
Glen Mills, PA, USA
  • Global Moderator
Re: New DT tappet adjusters
« Reply #1 on: 28 Feb 2016 at 02:56 »
Note: Examples of OB tappets have been seen with 1/4-26 thread. So when retrofitting to earlier tappets, be sure to check the thread. These only work with tappets tapped to 7/32-33.
