Author Topic: TS flywheels for sale  (Read 3432 times)
« on: 12 Aug 2013 at 22:58 »
Flywheels and drive sprocket assemblies, a couple with smaller taper, one with larger taper. Suit veteran/vintage 2 3/4 TS Douglas. Heavy to post of course, but let me know if you're desperate.
Offline John Simpfendorfer
Re: TS flywheels for sale
« Reply #1 on: 31 Dec 2013 at 01:44 »
Hi Cardan,
I'm new to the forum and restoring a 1924 TS.the sprocket I have is very worn.it's dimentison are as follows.31 teeth,spline taper 7/8" to 13/16"approx.,with a keyway of approx. 1/8"x3/16".can you help?
I live at Cootamundra,NSW.
Cost of Sprocket and approx.Postage.
Can I do direct dep.into your A/C ?
Cheers,John.
« Reply #2 on: 02 Jan 2014 at 02:02 »
Hi John,
Out of town and away from the flywheels for a while - I'll check sizes in a couple of weeks.
Offline spider2127
« Reply #3 on: 14 Aug 2014 at 14:06 »
Hi Leon, hey im also chasing a 31 tooth 6hole sprocket for my gearbox if you have?
1923 TS
Cheers Neil
« Reply #4 on: 14 Aug 2014 at 23:50 »
Sorry Neil. There are only a few odd 2 3/4mbits here and there (like flywheels!); sorry no gearbox sprockets.
Offline spider2127
« Reply #5 on: 26 Aug 2014 at 12:57 »
Thanks Leon what TS bits do you have left?
Im really chasing the 4x connecting rods thingys that join the two halves of the front forks together as well as mine the threads are u/s
Cheers Neil
« Reply #6 on: 26 Aug 2014 at 22:52 »
Hi Neil,
No, sorry. The fork links and spindles are the type of bits that are better re-made, as any originals that you find are sure to be worn out. If the club doesn't have them, they can be made pretty easily. Just make sure to use a correct grade of steel.
Offline spider2127
« Reply #7 on: 27 Aug 2014 at 04:04 »
Thanks Leon. Much appreciated for the info.
Ride safe.
Neil
