Author Topic: Footboards 600EW measurements  (Read 4285 times)
Offline BlueSilver
« on: 28 Nov 2011 at 20:23 »
Hello All,
My 600 EW is missing the footboards and now I will try to reproduce a pair out of a solid peace of aluminium. I only have photographs of the footboards but no measurements. I have made a drawing, and will ask if anyone can give me the measurements?
The measures are as follow, A = B = and so on. Thank you in advance!
Kind Regards, Leo
Larger version
« Last Edit: 30 Nov 2011 at 19:01 by Dave »
Offline john s
Re: Footboards 600EW measurements
« Reply #1 on: 29 Dec 2011 at 09:59 »
Hi leo i found a footboard to take measurements from
A  350mm
B 110mm
C 100mm
D 145mm
E 35mm
F 35mm
G 62mm
H 44mm
I 11mm
J 42mm
K 24mm
L ?
M ?
N ?
not sure about L M N from your diagram. can try to post pics if that helps let me know
regards john s
Offline TonyC
« Reply #2 on: 29 Dec 2011 at 21:18 »
Hi Leo,
         I produced patterns for these back in the 1980`s from which my Father had castings made.
         He still has a few sets available at 95 per set if this is of interest to you. Postage to the Netherlands would be another 20.
        I have attached a photo showing the castings along with footboards for the EW 350 and 2 & 3/4 models which, if anyone is interested, are available
        for the same price.
       Best regards
       Tony
« Last Edit: 17 Jan 2012 at 18:13 by Dave »
Offline BlueSilver
« Reply #3 on: 30 Dec 2011 at 19:54 »
Hello John,
Thank you for the measurements you 've send me. I will try to preduce one, it is a challenge to give it a try. I will keep in tough.
Hi Tony,
Thank you also for your reaction, and if I am not succeed I will order a set.
Kind regards Leo
Offline BlueSilver
« Reply #4 on: 25 May 2012 at 21:51 »
Hi all,
It took some time, but i've succeded. So here are the results of the footboards!
Kind regards, Leo
Larger view
Larger view
Larger view
Larger view
Larger view
« Last Edit: 27 May 2012 at 22:29 by Dave »
Offline john s
« Reply #5 on: 25 May 2012 at 23:47 »
nice job leo
regards john s
« Reply #6 on: 27 May 2012 at 10:34 »
Hi Leo
Did you make these yourself or did you commission someone to make them for you? They are fabulous! I'm sure there are others who would be only to pleased to be able to get footboards of this quality.
Cheers, Graeme
Offline BlueSilver
« Reply #7 on: 27 May 2012 at 17:59 »
Hello Graeme.
Yes I did everiting myself. It wasn't so easy as I thought,but I am proud on the result.
Regards Leo.
Offline Foppoli Matteo
« Reply #8 on: 26 Feb 2017 at 17:56 »
Hello, it's been seven years now since the last message, you can have a set for my bike Douglas   600 ? were redone? thanks Matteo
Offline TonyC
« Reply #9 on: 27 Feb 2017 at 18:03 »
Hi Matteo
Photo attached of the cast footboards
Cheers Tony
