Hi There
I am looking for specific information to enable me to manufacture the missing parts for my 3 1/2 hp project. I doubt whether there are many parts available and that people would necessary part with them, so I looking for detailed sketches so I can start to fabricate the many missing bits. Basically I have 2 and a bit engines, which is hopefully enough to build a good engine. I have an exhaust system for a pattern, a butchered inlet manifold with a mid 1920's Bing Carb. fitted, a Bosch mag. A gearbox complete with clutch & damaged pulley, a few bits of 4 hp clutch operating mechanism. A bare frame, with gear change mechanism and a funny sort of stand mounted at the forward end of the frame. I have a later 4hp steering column which I hope to modify but no fork blades, spindles or links I am missing a tank, hand pump or sight glass, carrier, mudguards, toolboxes, handlebars and controls, brake parts, though I have a couple of footbrake levers, and a foot clutch operating lever, I am not sure they are the correct ones, similarly I have front & rear hubs but again not sure they are correct. I know there are people making mudguards & beaded edge rims here in NZ, but I am not sure about a belt rims, but I see that there has been some correspondence on the forum about these so I can follow that up. I would be grateful of any help how ever small
Many Thanks
Steve L
