douglasmotorcycles.net
Welcome, Guest. Please login or register.
10 Sep 2010 at 17:42
Login with username, password and session length
Stats
13063 Posts in 3211 Topics by 929 Members
Latest Member: Syn
Search:     Advanced search
* Home | Help | Search | Login | Register
douglasmotorcycles.net  |  Reference  |  Identifying Douglas Motorcycles  |  Topic: Douglas wheels? « previous next »
Pages: 1 Print
Author Topic: Douglas wheels?  (Read 1052 times)
Rakotulkki
Member
Offline
« on: 26 Oct 2009 at 16:46 »
Hi forum,
I am new here, hi all. I`m looking info about these wheels that i have. I think that these are from postwar Douglas, can someone confirm this? 40 spokes both of them, front hub is very "thin" and it has 7" brake. Thanks for any info.
Best wishes,
Jami
« Last Edit: 27 Oct 2009 at 09:54 by Dave » Logged
eddie
Senior Member
Offline
« Reply #1 on: 26 Oct 2009 at 18:04 »
Jami,
         The rear wheel is standard Douglas as used on all postwar models from the 1947 T35 Mk1 through to the early (1955) Dragonfly. The front wheel probably came from a Mk4 or 5 as it is painted metallic blue, but will fit all postwar models except the 80 & 90 Plus and late Dragonfly.
Logged
Eero
Member
Offline
« Reply #2 on: 26 Oct 2009 at 18:50 »
Terve Jami.
Mulla on yhdet Douglas 1947 Mark 1:sen vanteet. Ovat olleet kromatut, mutta paikkailtu noilla kaminaväreillä.
Muuten ne ovat hyväkuntoiset ja niistä saa hyvät maalivanteet hiekkapuhalluksen jälkeen.
Pinnat tilasin Juurikkalalta.
Terveisin
Eero
Logged
Rakotulkki
Member
Offline
« Reply #3 on: 27 Oct 2009 at 05:49 »
Eddie, thank you very much. Did they make their own hubs/brakes, or did they use some other manufacturer makes( British hub, Harwil...)? What about this front wheel with 8" brake, i think that this is from same manufacturer made.
Cheers,
Jami
Eero, onko pyörät sinulla ylimääräisenä? Laittele vaikka yksityisviestiä.
« Last Edit: 27 Oct 2009 at 09:51 by Dave » Logged
eddie
Senior Member
Offline
« Reply #4 on: 27 Oct 2009 at 07:19 »
Hi Jami,
             Early veteran Douglases had Chater Lea hubs - then after WW1 Douglas made their own hubs of varying designs up until 1956 when they 'bought in' British Hub units in an attempt to cut down the manufacturing costs of the Dragonfly.
          Regarding the wheel with the 8" drum - whilst very much like the Douglas design, the rivetted construction suggests that it may not be Douglas. Hubs used prior to WW2 had the brakedrum attached on a tapered spline arrangement with a threaded retaining ring.
Logged
Rakotulkki
Member
Offline
« Reply #5 on: 27 Oct 2009 at 13:29 »
Hi Eddie,
Thanks for clear up this. I tought that it was so similar than postwar hubs. Can anyone identify this wheel with 8" brake?
Jami
Logged
Pages: 1 Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
Mercury design by Bloc
Valid XHTML 1.0! Valid CSS!
Page created in 0.048 seconds with 20 queries.
