Well, I've bodged up the inlet manifold for now, but its not running at all properly, almost as if the timing was out.
I've checked the marks are all aligned, but dont have any technical paperwork whatsoever as yet.
The valve timing seems to be set up with changeover occurring at tdc (and no overlap).
Can someone please advise the easiest way to check the valve and ignition timing please.
thanks
phil
