Author Topic: my t35  (Read 4539 times)
Offline plymlightnin
my t35
« on: 16 Jan 2008 at 17:58 »
i have just found a t35 which is in a very sorry state can you please help me with identification the engine no is t35/s/647 gearbox is the same frame is t35/3/6922/3 there is no docs or reg with the bike so any info would be much appreciated before i start the restoration thanks and best regards ian
« Last Edit: 16 Jan 2008 at 20:15 by Dave »
Re: my t35
« Reply #1 on: 16 Jan 2008 at 18:56 »
Ian, From the details you have given, the engine is a T35 (Mk1) number 647 but the frame number quoted is incorrect. 6922 would make it very late in the Mk3 series. The correct number should be either T35/S/6922/3 for a Mk3 or T35/S/6922/S for a Mk3 sports. Obviously the frame has been changed at some time - this is not unusual as the early T35's were known for their frame breakages. From the pictures posted, it has been built as a standard Mk3 with a Mk1 engine/gearbox. If you later join the London Douglas Motorcycle Club, the membership secretary will probably be able to help with date of despatch of the original bike and/or the replacement frame, and even the dealer it was despatched to (which may help in discovering the original registration mark).
                       Good luck with the restoration,
