Marcus,
I had a quick look at the 3 belt rims I have and two have 7 plates and one has 6. Non consistent number of short spokes between the plates!. On the two with 7 plates, they have 3 short spokes between all of the plates except for one segment which has two short spokes. The one with 6 plates has 3 short spokes between all the plates except for two segments which have 4 short spokes. All 3 belt rims are slightly different designs and I don't know which ones (if any) would be original, or a later replacement (genuine Douglas part or repro - no idea). All have patina that indicates they were used in period and not recent repro's. One is still on a wheel which appears to be an original (this is the belt rim with 6 plates) and has not been dismantled recently.
(the two rims with seven plates have the number of short spokes between the plates as 3,3,3,2,3,3,3 (i.e. 20 short spokes) and on the other rim with 6 plates, the sequence of the number of short spokes between the plates is 3,3,3,4,3,4 (i.e. 20 short spokes). )
The plate always seems to be close to one of the short spokes.
Can take some pictures if that helps. I will have a look through some period pictures when I get a chance and see if I can spot what was the norm back then.
Hutch
